You have a cool idea. A brush with a Dremel sanding drum could give you the scrape effect and spot heat the area with a BIC lighter enough to push the area in for the dent may work. After painting, fill the scrapes with panel line paint. I have never tried this myself, so using a guinea pig body for experimenting would be in order. Show us how you make out. I’m sure it would be useful to others.
7 hours ago, Fantom said:
I did the rubbings on this car by dabbing different colors on the body and dragging it with a wide flat brush
That looked real at first glance
The crash damage is replicated using thick foil pressed onto the good panel, before bending it up and setting it by back-filling the panel with body filler (to hold its shape). The foil crinkles a lot more realistically than the heat-and-bend technique
41039696914_bf503f9092_o.jpgeleanor01 by aus_mus, on Flickr
40858293485_6a809413be_o.jpgeleanor02 by aus_mus, on Flickr
40858294165_7c9ccc2201_o.jpgeleanor03 by aus_mus, on Flickr
40858294625_ff564ef4e8_o.jpgeleanor04 by aus_mus, on Flickr
40858295235_971338a5dd_o.jpgeleanor05 by aus_mus, on Flickr
40858295805_65a8300514_o.jpgeleanor06 by aus_mus, on Flickr
40858319135_6afe723f1e_o.jpgeleanor08 by aus_mus, on Flickr
40858319605_a0fc7775cd_o.jpgeleanor09 by aus_mus, on Flickr
kruleworld...I'm guessing you're using heavier foil than the roll in my kitchen?
Is that like the stuff in a restaurant "doggie bag"?
14 hours ago, Bainford said:
Oven liners and turkey roasting pans are a good source of heavy foil. Cheap at the grocery store.
Well....I do have a turkey roasting pan in the fridge.......I wonder why? ?
