Chevy II Posted February 7, 2022 Posted February 7, 2022 Has anyone used any of the Dupli-Color engine paints? Says they are engine enamel, but contain Ceramic Resins. If so, what primer did you spray it over?
1972coronet Posted February 7, 2022 Posted February 7, 2022 I've sprayed engine paints over Tamiya primer (aerosol) and el cheapo primers (color place, etc.).
Fat Brian Posted February 7, 2022 Posted February 7, 2022 I would test any heat resistant paint before committing it to a model. You just never know what they've put in there and how it will react with plastic.
Dodge Driver Posted February 7, 2022 Posted February 7, 2022 Here's Duplicolor Pontiac engine blue over Tamiya primer. The engine is from the Revell 66 GTO. 1 1
deuces wild Posted February 7, 2022 Posted February 7, 2022 3 hours ago, Dodge Driver said: Here's Duplicolor Pontiac engine blue over Tamiya primer. The engine is from the Revell 66 GTO. Nice!....?? 1
Chevy II Posted February 7, 2022 Author Posted February 7, 2022 Thanks for all the responses. I have used dupli-color primer with no problems, but didn't know about the engine paints. Going to get some and test it.
tbill Posted February 8, 2022 Posted February 8, 2022 I’ve used tamiya primer, duplicolor primer and the no name black primer from lowes under the engine paint with no issues. 1
