I'm inclined to think it's a made up engine, rather than an actual replica. I'm pretty sure it's not a Diesel, it's too small for a Diesel engine of that era. I also don't see any sort of injector setup, or really an intake at all. Definitely an L head, so there should be an intake on the same side as the exhaust. The piping on the top looks to be the water manifold. It would be nice if there were more pictures of it on the site, and perhaps the manufacturer name of whoever made the replica.
I could be wrong, but I tend to agree with Bill's (Longbox55) take on this thing.
It looks to me as though someone has taken random parts from various sources, without really understanding their functions, and has combined them in a way that looks old-timey engine-ish...sorta.
If you go to the link and click on the photo, an enlarged version opens. There is a line of what appear to be exposed valve springs facing the camera behind the manifold-looking thing. This would indicate all the valves are in-block, in a single-file line.
In a real engine, this valve arrangement would necessitate both intake and exhaust ports and manifolding to be on the same side of the engine, as noted above. I see nothing on this model that's readily identifiable as either intake or exhaust manifold.
The plumbing on top of the head does appear to be coolant-related, as does the horizontal chrome piping connected to what appears to be a coolant pump, driven from a horizontal jackshaft.
I think it's a bogie., but I'm still hunting.
Closest I've found so far is this old 2-stroke Roberts aircraft engine. Somewhat similar water piping on top, but this engine breathes through ports in the cylinder walls and would have no need for valves or springs indicative of poppet-valves as on the model shown in the OP.
roberts-6-x-engine-side.jpg?w=625&h=341
Ya know, it could also be a 4-valve T-head engine! On the T-head design, intake valves are on one side of the block, exhaust on the other side--not an uncommon engine design a century ago.
Art
Art
Good call, Art !
This is a 3-cylinder, 4-valve (per chamber) T-head ('20-'26 American LaFrance) with the line of exposed valve springs like the OP pic, similar coolant plumbing...many things in common with the OP design.
This is the other side.
Zo, the OP pic appears to be at least a somewhat viable design for a large displacement, slow-revving engine of the early 1920s...depending of course on what the other side looks like.
Here's another somewhat similar design, a Teetor inline 6-cylinder T-head engine.
i do believe the site i found this was a source for model railroading accessories. despite their reputation for 'rivet counting', there's probably a 90% membership that will accept a 'plausible' solution. can't say either is right, but it's interesting to see how different people view things.
I seem to recall that many train guys get pretty intense over actual railroad rolling stock and locomotives, but not so much about scenery and load items. Seeing as how this is G-scale stuff, which commonly mixes slightly off-scale bits (HO was still pretty prototype-correct last time I looked) it's not that surprising if this isn't a representation of an actual engine.
  On 2/27/2015 at 8:52 PM, Ace-Garageguy said:
Good call, Art !
Actually, Bill......
That's a SIX cylinder ALF engine. It has three "two cylinder" blocks, on a common crankcase, but it's a perfect example of a T-head engine: Intakes on one side, exhaust outlets on the opposite side.
Art
Art
Oops. Yup, you're right. So only 2 valves per cylinder. My duh. :D
Good call, Art !
How many spark plugs that thing have?
I know it's not uncommon for emergency equipment engines from that era to have multiple ignition systems....but I've never seen 3 per cylinder if this is in fact a 6 cylinder
